I have been using the UV Cure from wwwDOTepoxies.com  Replace DOT.
I am on my 5th gallon in 3 years.  I made the cure table with 3 four foot shop fixtures and UV Black Light's.
I do Epoxy Dome Fire Tags AccountabilityTagDOTcom
The UV Cure will yellow slightly, the 2 part will yellow less.
60-7155 is what I use.  I buy from them as I believe they make the epoxy.
They do send free samples for you to try.
Depending on how and what you print the sticker with, if the ink has a UV protected in it then the UV Cure can slide off later due to not curing at the junction of the sticker and the underside of the dome.  You will see the ink jet guys on you tube cover the sticker sheet with a clear vinyl then contour cut and dome.
I still have not gotten my FC7000 to use registration marks and cut stickers....  I think I am putting the registration marks on the top too close to the first sticker....   Saw here that it had to be 2 inches away....  Will try that.
AL
