double faced lit cabbinet ? please
Maverick Signs
i have a customer that has an existing box on pole and just needs the inserts. im asuming polycarb would be the way to go.
the dimensions are 5'x8' (2 faces )
anybody know a good supplier for having them direct printed
and what process will last the longest as far as being colorfast.
id also like to guote him for having it formed were parts of the
design are raised. whats that called and who offers this?
what are you averaging for this
thanks all
dug seeing all your mugs
MrSigns
Confirm sign has flat rigid faces. Not flex face. If it has a pan face then chances are you'll need to go back in with a pan face. Otherwise you have a good chance of creating hot spots. The lamps will be to close on a flat face creating brighter and dull areas of illumination.
I have used Econochannel. Always been satisfied. Send eps file for your embossed pan face. You should be happy.
