Yes, thanks. That one is single sided.
I've seen the double side that are clear and read Exit properly from either side.
You can select double sided clear as an option, sorry I thought the link was going to reflect that.
CONSTRUCTION
The ELRT Edge Lit Exit
Sign housing is constructed of die-cast aluminum housing with an etched, clear acrylic panel. Double sided panel comes as mirrored configuration. Lettering is 6” high with 3/4” stroke. Aluminum housing is standard, black and white housing available.
I'm assuming 2 layers of mirror acrylic sandwiched together would do the trick. Interesting application though, can't say I've ever seen/noticed these before.
