Double sided clear exit signs ?
packratsigns
Does anyone know how these are made ?
I heard a mirror layer may be used ?
Don't have one to take apart.
Any pics ?
Looking to make something similar with different text.
packratsigns
Yes, thanks. That one is single sided.
I've seen the double side that are clear and read Exit properly from either side.
White Haus
Not a Newbie
You can select double sided clear as an option, sorry I thought the link was going to reflect that.
CONSTRUCTION​
The ELRT Edge Lit Exit Sign housing is constructed of die-cast aluminum housing with an etched, clear acrylic panel. Double sided panel comes as mirrored configuration. Lettering is 6” high with 3/4” stroke. Aluminum housing is standard, black and white housing available.
I'm assuming 2 layers of mirror acrylic sandwiched together would do the trick. Interesting application though, can't say I've ever seen/noticed these before.
