double sided decal
stickersteve
Has anyone had any success on the gerber doing a two sided static cling window decal? Even when I sandwich a color in between I can still see through the other side when light hits it.
Steve
iSign
the middle should be a sandwich of white-grey-white, and then your actual image would occur on each side of the 2 whites
signage
As ISign said either use White-gray-white or white-silver-white! If you use anything darker than Gray you will need to hit the white twice on both sides!
