DX-A / DX-B from Digital Sign Tech cleaning solution for DX4 – real results?
adielm86
Hi everyone,
I’m working on recovering a few DX4 heads that are still firing but have partial clogs and some deflected nozzles. I’ve already done long soaks with regular eco-solvent cleaner and gentle syringe pulls, and while I do get some recovery, it feels like I’ve hit a limit where the cleaner just isn’t strong enough to break down whatever is still inside.
I recently came across DX-A and DX-B cleaning solutions on a supplier’s site, but I haven’t really seen people talk about them here. I’m curious if anyone has actually used them on DX4 heads and whether they made a noticeable difference compared to standard flush.
At this point I’m just trying to push these heads a bit further before replacing them, so I’m open to trying something stronger, but I’d rather hear real-world experience first. If you’ve had better results with something else—like carbitol-based mixes or other solvents—I’d appreciate any insight.
Thanks in advance.
netsol
i generally add 5-10% acetone to manufacturer's cleaners
since your heads are still printing, you have a reasonably good chance of sucess, more so if you invest in a chinese knockoff of a printhead doctor (or OF COURSE the real thing
an hour of soaking with the cleaner/acetone mix should be a big improvement AT YOUR OWN RISK followed by a a good thorough rinse. flush more than you think is necessary
  • Agree
Reactions: 1 user
damonCA21
Or... chuck the heads and buy new ones. They are consumable parts of the printer. You probably have about a 5% chance of ever getting them fully back and printing properly.
damonCA21
As an addition... I have seen all the print doctor and chinese copies and various people claiming they can recover heads with magic solutions. NONE of these people sell cleaned restored working heads, which says a lot about the success rates
Stronger cleaner can help for sure. Sometimes it's just physically damaged nozzles that won't ever recover.
  • Agree
Reactions: 1 user
netsol
Vlad, who developed the print head doctor has a 'chemist" on staff and works with people with the genuine printhead doctor suppying mixes of cleaner
to accomidate your inks. i always believed the print head doctor is best used while the heads are still producing an acceptable print. it is not magic but
can work wonders keeping a head in good shape. no one will EVER be able to buy up defective heads & sell them as restored
  • Agree
Reactions: 1 user
adielm86
I’m attaching a nozzle check and would really appreciate your opinion.
Do you think these printheads are still recoverable?
I already know I’ll need to replace the yellow and black heads since they appear to be electrically dead. However, I still have some hope for the others and would like to know if they’re worth continuing to work on or if I should just replace them as well.
Any advice or experience with similar cases would be greatly appreciated.
cornholio
Look at the nozzle line with a magnifier. If you see discoloration around the nozzle lines. (lighter metallic instead of the datker brownish like the rest of the nozzle plate)
You have likely corrosion at the nozzles and they will have deflections you can't correct with any snake oil.
  • Agree
Reactions: 1 user
damonCA21
No chance.Those aren't just blocked, the nozzles are deflecting as well
Smoke_Jaguar
I do, but they are also expensive. It's a time-consuming process and there are some ridiculously toxic chemicals in some of the cleaners. That said, I do not sell to the general public, but some Chinese companies sell refurbs. That said, stronger solvents can shorten head life, especially on Epson heads.
netsol
yes, you really have to find the sweet spot, clearing clogs & NOT DAMAGING the nozzle plate, seals, etc
