Edge Caps
Sign_Boy
How do you all charge for edge caps?
They are such a PITA!!!!:banghead::banghead::banghead:
Do you charge by the foot?
Just wondering, if I ever do these things again I want it to be worth it!~!~!!!
imaSIGNr
I don't like the regular silicone for any use. I use the " Geocel " brand clear for edge caps or any other household thing. It's better. Cost about $7 a tube but worth it. I also take a small piece of sand paper and rough the inside of the cap so the adhesive gets a better grip.....I also use tiny copper nails every 8" or so ( on MDO ). I pre drill and put a drop of super glue on the nail, then a spot of paint over the nail head....
Sign_Boy
Great tips, thank you I'll have them next time I do edge caps.
GregT
We keep the edgecap clamped for a short periiod of time. It does expand but we haven't had a problem. You need to make sure you don't use to much glue. We use just a very thin bead.
Doyle
I charge $2.00 a foot and use liquid nails, but sometimes have trouble getting a good bond.
Jillbeans
I typically include it as part of an Alumalite sign.
I use silicone. Gorilla Glue is too brittle and grows too much for my liking.
I like the idea of sanding the inside of the cap.
You have to be careful when clamping Alumalite so you don't pinch it, use cardboard under your clamps if needed.
Usually after a few years the bottom piece will droop.
I rarely use MDO, and when I do I just seal the edges with two coats of Titebond 2, prime, and paint. I did use ½" Lusterboard on a big job once, did those edges the same was PLUS edgecap.
Love....Jill
