electrical sign cabinet question
cajun312
I'm quoting a job for a State Farm Insurance agent, it's for a 6' wide x 8' tall cabinet.
These are the specs sent by State Farm:
3/16th inch thick, UV-inhibiting non glare clear polycarbonate (example-Makrolon-Sign Grade Matte or equal)
State Farm does not want a pan faced panel in their new signs. Will the material spec be strong enough for a flat panel sign in windy conditions?
thanks,
Mark
Looking at the state you're in you'll probably want to use bumpers, or use a hanging bar that's mechanically fastened to the top, and maybe a few on the sides and bottom concealed by the retainers. Drill the holes of the substrate larger than the fastners to leave some room for expansion and contraction
Single sided or double?
cajun312
It's double sided.
jeffblair5
Is this a new sign or just new faces? They do allow for pan faces if you are just replacing the faces. I've done over 100 agents in the last year and some new signs even allowed for pan faces. I'd submit your drawings for both pan faces and flat faces and see what they approve.
cajun312
It's a new cabinet. The State Farm agent is trying to get permission to use pan faces but no luck yet. State Farm did turn down her request to use formed plastic lettering on the building as I quoted her back in the spring, they now require cut acrylic letters only, which are more expensive than the formed plastic.
She is not a happy camper at the moment, this job has been dragging on for a year. State Farm is using a new company to come up with specs and they are slow getting things done it seems.
Mosh
I am in Nebraska, I installed a state farm sign on a couple pan faces last summer and didn't have any problems.
Sometimes it is the agent trying to be too anal...
cajun312
State Farm went with a different vendor late this summer who handles their marketing as far a signage goes amd tjeu introduced new specs, they must approve everything on the job, agent can not approve it.
