Maybe time to join the cult of Apple? How does Flexi work with Apple? I have been using Flexi since the early 2000's and would hope it is pretty much the same on Apple vs PC...
Thanks for the info. It is my main computer for design and cutting vinyl plus email and browsing, so maybe I need to upgrade but fearful of how Signlab will deal with it...running version 8Your probably OK for continuing to use Win 7 for the next couple of months as should be getting the last round of updates. You might be able to extend protection by being behind a good firewall (software based firewall is not what I'm talking about here, a true dedicated firewall) and browsers will be likely updated for quite some time. If you are smart about your web browsing, probably extend the life a little bit more as being connected online is the biggest vector of vulnerability.
However, make no mistake about it, there are vulnerabilities and it would take a big one for MS to patch Win 7 for it and then again, they may not due to how long it's taken people to migrate of XP (which ironically didn't start off as that great of an OS either). Shoot even Win 10 still has blobs of legacy code in it (and 32 bit libs really need to be removed, they really do).
If you can take your Win 7 machine offline (which is something that I would highly suggest anyway for a production machine) that would be the best thing to do. Get something current to browse the web with and do web related activities.
Upgrade in of itself, isn't that big of a deal, but I've always been a big advocate of fresh install. If running older computers, replace those with hardware that will definitely work with the newer software/components. Does the hardware have support for Win 10 etc? Some do, some don't. Drivers have always been an issue with doing the upgrade versus fresh install path. One of the nice things about having drivers baked into an OS versus reliant on 3rd party, but that does have it's own con as well, if there is no support, there is no support period.
As I said "if you're computer savvy", which means you know how to check to see if there are drivers for your hardware.
Though sometimes install stalls because Windows 10 Setup tries to find drivers on the internet and just stalls out, the solution to that is to not be connected to the internet while installing.
If you want to do a clean install it's still free. As I said "if you're computer savvy", which means you know how to check to see if there are drivers for your hardware.
So I have to very similar machines, a few years old. I was able to successfully update the slightly older one to win 10, went smoothly. The second machine, got to the checking for updates like you mentioned, and blue screen errors galore. Got it back to win 7 without data loss. Unplugged all my printers, plotters, dongles, etc leaving just the mouse and keyboard and 1 screen. Left it installing overnight (slow internet) came in the morning and it had just reverted back to win 7 on its own... as if I never tried to install. Although I checked the updates logs and it said failed install error code xxx, which I looked up and suggested likely driver associated.
I'd rather not do a fresh install, IDK just seems like a pain to reinstall all our software and and settings... unless I'm missing something here and it's actually easy to do..
But you say unplug the internet to install. So would I runt the media creation tool again but download to thumbdrive, then use that to update the computer with internet unplugged? This should bypass the step of windows trying to update my driver and allow the install? Will the driver update automatically or easily once I'm on windows 10 with an internet connection?
I have 10 on all my computers. My boomer mom has 7 on hers, she is freaking out about the support ending. I asked her what she is worried about, she really couldn't tell me.
If anyone has advice on how to continue to use older computers it would be appreciated by many I'm sure. For example, I have a number of Windows XP computers that I use to run certain equipment and/or software that can not be used with newer computers. I need to have these computers connected to our internal network but do not need to have them connected to the internet and be vulnerable to outside viruses and malware, which our internal network is connected to. With the end of support for Windows 7, I will now have many more computers in the same situation, probably like many other people will too. What is the best way to have these computers networked but safeguarded?
