jdwilliams1
welp the art board only didn't work
about to pull my hair out here...
Open a new file in illus. Make a simple square. Save it and print it and see if the same thing happens. If so it is not in Illus, if not than it is your file and it is something you have just overlooked.
most likely you have a problem at your printer. if you are placing your sign blank on the table, and it is printing higher than the bottom of the sign blank, then where you think the start point is and where the print thinks the starting point is are two different places.
if both prints gave the same results, then it is mostly a setting on the printer. why not just move the sign blank up to compensate?
