Epson S60600 Won't Stay Clean
JulieS
I'm having this issue where I'll start out with a clean test print, but in the middle of maybe a 3' print, I start getting banding. Do a test print, and I'm missing a nozzle or two, never the same ones (I don't think). I'm having to clean very frequently, like between every print. Any ideas?
Thanks!
Glavin_ID
I’m having the same issue, have to do manual clean a ton, not between every print but pretty much every day. We also seem to get banding whenever we use the take up reel even though we have clear nozzles so that’s fun too.
  • Sad
Reactions: 1 user
Grizzly
It’s all about your print!
Couple of things that could be happening. I don't have an Epson so not sure with that particular model, but inkjet printers in general all have similar issues.
1. The head(s) could just be going bad. The older they get the more I've noticed they can print a perfect nozzle but not sustain in printing. Since they're firing on a nozzle test, it means they're not totally blocked.
2. Ink delivery issue. The pumps aren't working as they should and are not pumping enough ink into the reservoir or pumping air bubbles which causes nozzles to drop out.
3. Low & High pressure issue. On my flatbeds, I have two air pumps, one that attempts to pull air out of the ink lines, and another that holds the ink right at the firing nozzle so it doesn't drop out nor does it get sucked up back into the reservoir. If the Low Vaccum is too low, ink just falls out of the heads. If it's too high, it pulls the ink back up into the reservoir and then your nozzles don't have ink to fire and end up firing air causing drop out.
  • I Appreciate You
Reactions: 1 user
Jungteam
I'm not sure if it is the same issue or not.
Normally, if the print head is too old, missing nozzle is coming during printing.
Or, if the damper is too old, it is also happened.
especially, I got the problem report that the color is suddenly changed during printing even if all nozzle test was OK.
Then, I ask them to change the damper at first.
For the damper issue, please check hereunder link.
Another thing, if your printer hasn't the good waveform for your ink, it happened.
Most of time, printer manufacturer make this waveform based on their ink before they launch the new model.
  • Agree
Reactions: 1 user
