Etched Glass Vinyl Pricing - Full Coverage on 8 Windows
visionsigns
I need to establish a price on installing etched glass completely covering 8 windows (all different sizes) on a conference room.
The window sizes are
115"x45"
115"x43"
115"x33"
115"x33"
115"x29
115"x13"
31"x36"
68"x23"
It is a total of ~ 177sq ft of window space but using 48" wide material I would use ~ 236 sq ft of material.
Also, are there any tips or tricks to applying the vinyl since there is no way to hinge the vinyl?
visionsigns
Forgot to add the cost of vinyl:
@ Fellers - Oracal 8510 48" x 150' = $538.50 or $.90/sq ft
So cost would be ~ $212.40 but I'm having to buy $538.50 of the vinyl
Checkers
hehehe, you don't want to know my pricing because a job like this has a lot more value than the cost of material and labor.
Just for kicks and giggles, is it going indoors or outside and are the windows 115" tall? and can they be easily reached without a step ladder?
Checkers
red91_sc
I am not very good at pricing yet( I rip myself off each time), but just for vinyl I would charge $861 plus cleaning time and the install so roughly $950 for everything.
visionsigns
Thanks everyone for the feedback.
Brian - 115" Tall windows (9.5 ft Tall). Probably need 2 step ladders. They are inside windows that divide the reception area and a conference room. If they were exterior windows, I'd say see you in the spring!
Any tips on applying it? I've done plenty of partial window graphics where I can hinge it to the glass. But I don't know how I would get started.
I made this diagram to show the window and the piece of vinyl about 1" larger than the size of the window - the excess to be trimmed after applied. Wouldn't the vinyl get bunched or folded in the corners before it's trimmed?
Doyle
Try cutting a small strip of the backing away (VERY carefully) across the midsection of the film, from one side to the other, say 1", and use this as your hinge. I've done this a few times with success.
Doyle
The only problem with this method is if you apply too much pressure with a knife when cutting that backing, you will ruin your entire piece. I suppose you may be able to do this at the top or bottom of the vinyl instead of the middle. Just cut off the first couple of inches of the backing and do a top/bottom hinge instead. But it is usually harder to apply that large of a section without problems than doing a half at a time.
As for price, I think that I would charge around $1500 - $1600 total
Use lots of Rapid Tac and lots of pressure.
Close to about $2,200.00 to $2,500.00 no travel included for two people.
I might even add in an extra $300 or 400 for insurance in case something goes wrong and take two extra window kits along. Ya never know...:rolleyes:
If you were wholesaling this.... about 37 cents a square foot seems adequate ??
LaKe
I'd mark your vinyl up 500% or about $5 a sq. foot. Add $2-3 sq. ft to install. Installing it use Rapid tac to help but make a hinge at the top by peeling back the first 2-3 inches and squeegins that down dry (after your sheet is squared up use masking taper horizontally across to help hold it in position) then after that is stuck work your way down to the bottom peeling the backing off as you go down..wet it if necessary...works for me. I did a 14' x 25' install that way and worked fairly well. It wasn't etched material but the process should work for you.
Checkers
Gino's got the right idea and what I would think is a decent price. I didn't do the math though.
You can apply them with Rapid Tac (not RTII) and no mask, and trim them to fit. But, it would depend on the finish around the window. If it's a nice wood or painted finish, I would apply mask and cut the graphics shightly undersized, leaving about 1/4" exposed around all the edges. Then apply them dry using a top hinge. Just make sure your squeegee is nice and sharp and it has no nicks.
Gino's got a good point about the extra $300-$400 on a tricky job, which this sounds like it could be. I normally figure an additional charge of at least 10% as an "oops factor", which should be enough to cover "do overs" on 1 or 2 panels.
Checkers
visionsigns
I really appreciate all the feedback. It's a tremendous help.
Would you recommend applying the etch to the glass from the inside of the room or outside the room? Or should I let the customer decide?
