did you say 15 thousand pounds?!?! no way in hell it's worth that much! it came free on our machine.Thanks for reply!
I do a lot of intricate kiss cutting when I cut sometimes 50 meters of material so it would be amazing to speed this up.
My machine runs 10hours a day non stop. Cutting, routing, kiss cutting that's why I Am bit worried about frying my motherboard.
Where did your concerns came from? Did machine acted weird or started to struggle?
It's 15000 pounds for upgrade and I don't want to spend that much money just to turn it off for the safety of the machine...
F Performance has no issues with hardware failures - it’s a misnomer that came from a couple of unconnected faults some time ago that got misunderstood.
I have put hundreds of these machines into the market and every one has gone in with F Performance switched on by default since launch - we don’t even bother mentioning it to new users now the marketing push has died down. I bet most don’t even know what it is. Zero board failures.
Sure about that? Pretty sure there are a couple of members here that would tend to disagree with you.
You may not have personally encountered any issues but I would have to say "zero board failures" is incorrect.
Here's a copy paste reply directly from summa tech support:Not sure how I can quote from anything other than personal experience? It just doesn’t happen due to F Performance here - if it did I would have seen it by now we’ve shipped three figures of these cutters. Sure we get the occasional board failure but never due to F Performance. If there’s only a couple of people with issues on here it’s likely to have been wrongly ascribed or sheer bad luck. People should not be put off this upgrade it isn’t a threat to their machines it’s been out for years we would have seen solid evidence by now. Sorry - just my own experience.
That was 2021, any updates? We don't run F performance on our Summa but it did come with the option. This is our first flatbed cutter and we like the speed it has at standard.Here's a copy paste reply directly from summa tech support:
Thank you for reaching out regarding your new Summa F1612 and Thank you for your business and confidence in Summa.
We are currently temporarily recommending de-activating F-performance. We have had a recent uptick in carriage board failures and although it is not conclusive that F-performance is the root cause, it is a variable that we can "turn off" to reduce risk.
Summa is actively in the process of correcting this issue and will send a channel wide dealer bulletin with the update very soon.
In the mean time please correspond with your dealer for any questions or updates.
I did pop a couple of boards, but do still have it activated on mine. I just don't run it at full speed.That was 2021, any updates? We don't run F performance on our Summa but it did come with the option. This is our first flatbed cutter and we like the speed it has at standard.
Don't jinx me Phil!!! hahaAll the F1612-3x & F1612-4x machines have the newer carriage boards so if you have a machine build date after 2021(the third and fourth digit of your serial number are the build date year) you can utilize the F-Performance upgrade. If your machine was manufactured prior to then, you will want to swap the carriage board to the newer version before enabling F-Performance or you will likely blown the board.
Best regards,
Phil Johnson
Airmark Corporation
(800)527-7778, ext. 112
[email protected]
