jonathantill
Getting a E072 Y Timeout error when trying to do a nossle check. It prints the first line of test and then comes back to the carriage, then goes back and prints the first past of the second test (Diagonal lines) and as it is about to come out of the capping station it stops and then i get this message. I was having a problem (or what i thought was a problem) with the paper check when i turned on the machine so at some point i reset the home position and I think this might be causing part of my problem. I have cleaned the encoder strip and the reader. I have cleaned most of the sensors that i can find (sensor on the print head carriage, encoder reader, home position reader, xr sensor). I have also checked the tension on the y belt/motor and there doesn't seem to be a problem. I took a pair of pliers and gently held the shaft of the motor and could not move the carriage without the motor turning so the belt isn't slipping either. I also get the same result when trying to run the y motor aging test but the motor and carriage both work fine until that third pass of the nossle check. Does anyone have any other suggestions? Thanks, Jonathan
