File Conversion Emergency!!
Signsforwhile
I used to have an edge. We switched to a valuejet and no longer use omega. I removed the security dongle for omega because it was conflicting with the flexi one and now cannot find it. And now need to use something from an Omega file.
I need a path converted to an eps, ai...or anything flexi will open out of an Omega file. I can send you the omega file and you could send me the eps or ai. Any help is greatly appreciated!!!
Since I do not have the dongle Omega only runs in demo mode, which does not let you export...
Fred Weiss
You have a couple of other options open to you.
  • All versions of FlexiSign 7.62 or later will open a Gerber PLT file
  • The Omega File Converter utility application will export to AI or EPS without requiring a dongle
