FindMyFont
Hello to all type enthusiasts,
Find My Font font identification software has just released version 3.1 .
The main improvement in the new version is the addition of a deformation correction tool. With this new tool you may correct all kinds of image deformations in one step. The tool is pretty simple and will save you a lot of time especially when selecting a letter to identify is difficult.
The one step process involves dragging a few control points around the deformed area. A preview area helps you verify the result before performing the correction. Since a photo is worth a thousand words here's one that will help you understand what I mean:
As you can see, letter selection will be much easier (and correct) in the fixed image.
Besides deformations the same tool can also be used for:
Other improvements of this new version include:
As always the updates are free so I urge anyone using a previous version to update and enjoy the new features. Select the Check for Updates command from the Help menu
I would also like to remind you that:
Users of the Basic edition should update to get online matching too.
An affiliate program is available for those who want to share the news (and make a buck or two).
I want to thank everyone in this forum that has helped make Find my Font an indispensable tool for font identification. Your comments and suggestions is what motivates us to improve our product.
![Thank You :thankyou: :thankyou:](https://signs101.com/images/smilies-orig/standard/thank you.gif)
Harris
![deformation-steps.png deformation-steps.png](https://www.signs101.com/data/attachments/70/70219-cef6d6044b29794cca6103e9b263b54c.jpg)
- Image enlargement
- Image mirroring
- Contrast correction
- Image expansion
- Network Parameters: The program now allows the user to indicate if he's using a proxy to connect to the internet and the parameters for the connection.
- Improved Baseline Rotation tool: The tool now shows vertical lines to make the 'horizontalize' operation much easier.
- Tool tips: The new tool tip area provides useful information about the selected tool. The user may also adjust the tool's parameters in this area.
Harris
