Hey GEB ---
I've seen that before and I always thought it was a Mac/Illustrator/Coreldraw/Gremlin thing. I'm a Mac guy by the way.
I could never figure it out. I'd save an EPS file out of Illustrator and open it in CorelDraw and I'd get the TIF preview image. I'd save it as an AI file and I'd get the vector image in CorelDraw.
What software is the original vector file in?
The part of your post that spooks me is that you say that you are converting it. To me that implies that you're changing the structure of the art some how making it a bitmap image. Maybe not, but that's me. In theory, the AI and EPS files should preview identical to each other in the software that you're using.
The other thing you might try is saving it back a couple of versions to see if it still acts weird.
I'm not sure how to do it in CorelDraw, but the basics of how I would do it in Illustrator is:
Select the original color yellow and change all of that to 15% - 20% Black. Select your blue and change that to 20% - 30% Black. Select all your purple and change that to 100% Black.
I pilfered you JPG off you post and found that the Yellow is 30%, Blue is 31% and the Purple is 69%. Again,it's an aestetic thing with me, but I'd go a touch lighter with the Yellow and Blue and 100% with the Purple.
You should be able to export that out of CorelDraw as an EPS file. Again, depending on which version you have, you may want to save it back a couple of versions. That's worked for me on occasion.
Just a thought...
