CizreK
Graphic Designer & Print Production Manager
I’ve been running a Xante X-55 Flatbed (Dual Head CMYK + White) for about 3 years. I recently overhauled the system myself, replacing the pumps to fix a back-drafting ink issue. Print quality is now excellent, but I’m fighting a major ink adhesion/peeling battle on Coroplast.
Questions for the Floor:
This is my first post here - sorry if its a bit heavy. Just going thru some struggles right now. I just want to know how Signs365 gets their prints so evened out.
- Ink Adhesion: Prints look great and pass the "dry" scratch test. However, if the signs get wet or hit temperature swings (Southeast US humidity/heat), the ink peels right off. You can spit on it and in 2 minutes peel it off with the same scratch method.
- The Specifics: Major issues on 6mm Coro (Grimco), but curiously less frequent on 4mm. Full-coverage specialty brand colors are the worst offenders.
- Current Prep: Windex/Vinegar wipe down, dry rag, then paper towel. Print head height is <1mm. UV Lamps at 80%.
- Current Software/Settings: iQueue. Uni-directional. Traditionally used Photo Quality/Elegant Screens at -8% to -10% density to prevent cracking.
- Screening: Switched from Elegant to Standard Halftone (133 LPI).
- LPI Tweaks: Tried dropping to 30-40 LPI. It seems to bite better, but the dot separation is visible and light-bleed is an issue.
- Angles: Research led me to 15, 0, 75, 45 for CMYK angles.
- Mode: Testing "Production Mode - Max Speed" at 1440 quality is best or Sign quality is ok but lays a bit thick.
- Coro Prep: Is Windex/Vinegar actually hurting the "bite" on UV ink? Should I be using 91% ISO or something else?
- The "6mm Mystery": Why would 6mm peel more than 4mm? Is it a heat-sink issue with the UV lamps?
- iQueue Settings: For those using Xante/iQueue, what LPI and Screen combinations are you finding give the best adhesion for full-coverage blocks?
- Lamps: Should I be cranking the lamps up more, I know that will that cause the ink to become too brittle and peel but just wondering.
