Flatbed Print and Cut pricing
vicvilla
What’s a general per sheet charge to an end user for a 4x8 and 5x10 size sheet good and routing 6 multiple star shapes - direct printed cmyk and routing to shape?
FireSprint.com
Wholesale Signs, Stickers, Banners-Free Shipping
So many variables here. From about $30 a sheet, low wholesale, to $800+ a sheet high retail. Not even kidding.
Here's a tool to get your started:
vicvilla
Actually Haus was trying to get a range without substrates involved in the price. Ill be more clear next time but thank you for taking the time out of your day to be so kind. No need to reply Sir.
parrott
Different medias will run at different speeds for printing and cutting. Corrugated vs magnet cutting is totally different. 1/2” foam vs 3/16” foam is different for cutting.
Most of all our materials are printed on the same speed but that is not the normal on most machines. Cutting can be a huge factor. You can get burned on the details if not careful.
All depends on printer/cutter etc. We run boards at approximately 50 seconds a board (for printing) where another shop may spend 5 minutes per board. We calculate our price by the square foot for printing and based off labor rates for cutting.
Don’t forget to factor in blades, bits and clean up (especially for routing).
vicvilla
Hi Parrott- This is very useful and thank you very much. We mostly us 3MM ACM .080 sign white and the other stuff is usually 3/14 or 1/2 gator. Ill find out more about how our guys set up the time but guessing we are closer to 5 minutes based on the various shapes and clean cutting we go for. Im finding they change the bit about every 10-15 sheets apparently so will factor that in as well. Thank you for your experience on this!
Eforcer
Sign Up!
This question should have been predetermined before getting a unit that can print & finish the work. A sheet x 3.5 cost. Time; setup and margins you need to afford the mortgage on the unit. JMO
Sign Up!
vicvilla
Understood- Im not doing an equipment analysis for purchase done many years ago- just seeing if the average around the nation to charge an end user for a 5x10 flatbed print with routing time of about 5 minutes per sheet is. Im sure its between $100-$1000 not including the actual substrate. Just curious really
Im sure their is a better way to ask or maybe too personal for folks to share. Anyways appreciate the feedback.
Eforcer
Sign Up!
Always ask. That is what this forum creates. A field of wise and helping peers. Me personally, I'm just jealous you have a toy I don't have...
Sign Up!
I totally agree. To simply buy a machine and not know what it is worth TO YOU is just incredible. Only you know what it'll take to keep your door open and people paid. You have enough other equipment from which to kinda figure this kinda data out. How did you obtain those numbers. This is no tongue lashing, but how do people buy these things without even putting a foot in the shallow end of the pool ??
vicvilla
vicvilla
Sign Up!
I dont actually either just a sales guy trying to sell stuff people like for a fair price. Thanks for the positive feedback. tough crowd
You quoted and left me with nothing. What's up ?? Cat got your tongue. Maybe navigation around here is tough.
