Flexi 7.6 Windows 7 64bit OS???
So I installed it and the HASP Key Driver installed fine and Flexi still won't load?
Tried running it as administrator......didnt work?
Tried running it in XP Service Pack 2/3 mode.....didnt work?
It says the hardware key is not found, but it installed and shows up in devices and printers folder?
Any suggestions anyone?
javila
7.6 wont work on 64 bit 7 because part of flexi 7.6 uses a 16bit process which are no longer supported under 64 bit.
Ok, so i got it figured out! After about 2 hours of research and a quick call to Steve Rife at Beacon!
All you have to do is go to windows website and download the XP emulation & Virtual machine and run XP as an emulation! Everything works great!
