Floor standing sign: How to weigh it down
mvanmeter
We're looking at quoting a floor sign which will be about 5.5' tall with a 1'x1' base.
To prevent this from falling over the first time someone runs into it, we will need to add hidden weight to the base. What have people used to do this? In order to keep the weight hidden, it will need to fit within the confines of the 1'x1' base.
Short of depleted uranium and lead, what have people used and how have they hidden these weights?
Thanks!
Mike
letterman7
Are you making this? Plenty of off the shelf floor stands with weighted bases already.. why try to make something?
MikePro
diy:
option a: a piece of 11.875"sq. piece of masking tape on the floor, and an 11.75"sq. piece of dbl.sided tape on the base of the sign.
option b: (attached image)
Desert_Signs
It's an architect's design.
As to the question of why we don't want to use lead: it's going into a hospital
Lots of lead in a hospital. Seriously. Lead is a shield against x-rays and hospitals that treat cancer via radiation have lead-lined rooms.
If the base is "sealed", you should be able to easily fill it with lead shot. You can pick it up in 25lb bags at most large shooting supply stores. Lead shot has a density of 470lbs/cuft, with a 1'x1' base, depending on height, you ought to be able to make it VERY heavy. You can also purchase steel shot. It has a much lower density (about 1/2 that of lead), so that may be an option if you're set against lead.
Rick
What size is the sign or sign holder going to be?
What material is called out for the upper portion?
I have designed some sizable stanchion bases using 1/2" aluminum plate, and some using steel.
Hopefully it's ADA compliant too, there are specific guidelines for protruding objects.
