Casey...any chance you can explain this in English?? I looked at the support document but quite honestly I don't have a clue as to where I would start with that.
If you are already upgraded, you have to roll-back the upgrade first:
http://www.howtogeek.com/220723/how-to-uninstall-windows-10-and-downgrade-to-windows-7-or-8.1/
You will need to be familiar with the Microsoft Registry Editor (regedit.exe) and /or
Computer Configuration.
Note: I had to restart the
computer a couple times before the upgrade and notifications disappeared.
Here are the instructions to block the upgrade for most of us (
some of these steps are from memory, we may have to adjust):
Method #1 Computer Configuration
Click
Start (or
Windows button on Keyboard)
Type "
mmc" (no quotes) in the search bar
It should find mmc.exe, click it or the enter key (approve any security warnings)
A blank console should open
Click
File
Click
Add / Remove Snap-In
Click
Group Policy Object
Click
Add
Next
Windows should say
Local Computer
Click
Finish
Click
OK
Click
Local Computer Policy
Click
Click
Policies.
Click
Administrative Templates
Click
Windows Components
Click
Windows Update
Double-click
Turn off the upgrade to the latest version of Windows through
Windows Update.
Click
Enable.
Close Console
Note: Policy path =
Computer Configuration / Administrative Templates /
Windows Components /
Windows Update Policy
Setting: Turn off the upgrade to the latest version of
Windows through
Windows Update
Method # 2 Windows registry
Important: Follow the steps in this section carefully. Serious problems might occur if you modify the registry incorrectly. Before you modify it, back up the registry for restoration in case problems occur.
To block the upgrade to
Windows 10 through
Windows Update, specify the following registry value:
Subkey: HKLM\SOFTWARE\Policies\Microsoft\
Windows\WindowsUpdate
DWORD value: DisableOSUpgrade = 1
You can also hide that persistent Windows 10 reminder
For non-Enterprise versions of
Windows, the notification icon can be suppressed through the
Windows registry. To do this, set the following registry value:
Subkey: HKLM\Software\Policies\Microsoft\
Windows\Gwx
DWORD value: DisableGwx = 1
