French Cleats
3Dsigns
Hi all, It's been a while since I've posted. I would like to know where to get a set of french cleats, or to build some, strong enough to support an 80''x96'' x2'' HDU sign against a block wall(my shop sign). I'm planning to laminate some .090 aluminum to the back of it with epoxy, as a backer, and then three french cleats would be bolted to this. So the thing is going to weigh somewhere between 150 and 200#. Or if anyone could suggest a better way to hang this that would be great. What do ya think?
10155504303150709
10155504303150709
Sandman
I've made french cleats with 3/4 MDO. Then attach with epoxy and countersunk bolts in epoxy wells. Found this on the precision board site as to how much weight a bolt in an epoxy weld in various densities of Precision Board will hold. Really helps with figuring out how many bolts needed for the sign weight. Works great on lighter signs because you have enough room to get behind the sign and run a screw through the two cleats to keep it from lifting or stolen. LOL
West System Epoxy / Precision Board Plus HDU Test Report - Coastal Enterprises
Ready
Ready To Go
These are sometimes called Z clips. Eagle Aluminum; Monarch Metal; Amazon; Just do an internet search and you'll get a lot of web sites with these.
Bob P
Marlene
I wouldn't use MDO for cleats. we just finished a bank conversion where the original signs, some fairly new, were hung with home made MDO cleats. most of the cleats were rotted.
3Dsigns
Yes, MDO doesn't last long at all here in Florida either. I quit using it for sign substrate many years ago. I'd rather stick with aluminum or stainless steel for my HDU projects. Why use something which rots on something that doesn't?
Moze
My two cents:
Masonry surfaces aren't always perfectly smooth. French cleats don't work too great if the surface has irregularities or is uneven.
If it were me, I would just cut a few keyholes in the .090" aluminum. Make a pattern of the keyholes and use screws and anchors in the block. That gives you some room for adjustment if need be.
signbrad
bolt 2" aluminum angle to the structure and weld angle to the aluminum backer and run a self tapper to mate them.
I prefer this method over the store-bought cleats. It is easy and quick. And if you don't want a 2-inch standoff, use 1-1/2" angle. Use heavy angle such as 1/4-inch wall.
A middle cleat may not be necessary, especially since a .090" backer is being glued to the back of the HDU, stiffening it considerably.
Further, the two cleats that mount to the wall can be made into a one-piece H-frame that can be attached to the wall as a unit, as in the drawing below. Once the H-frame is secured to the wall, the sign is mounted to the frame. The H-frame eliminates the necessity of making careful vertical measurements on the wall in an effort to make sure that all mating pieces line up.
In the picture, the two pieces that attach to the back of the sign can be flipped, so that the vertical leg on the top piece points up and the vertical leg on the bottom piece points down. I should have drawn it this way to begin with, but this was an improvement that was made after the design was done years ago. Flipping the pieces allows you to use 'structural' angle instead of the more expensive 'architectural' angle. 'Structural' has an inside radius the length of its inside corner that would prevent the mating pieces from nesting closely if installed the way I've drawn it. Structural angle is also stronger than architectural.
This entire assembly can actually be built and mounted on the back of the sign in the shop. Before the two independent angles are mounted permanently to the back of the sign, pre-attach them to the top and bottom of the frame with TEK screws, then attach the entire unit to the sign back. If you use Lord adhesive or some other high bond glue for the permanent bond, be careful that the removable part, the H-frame, does not get accidentally glued to the back along with the independent top and bottom pieces. At the job site, simply remove the frame from the back of the sign and mount it by itself to the wall, making sure it's plumb and level. Then slide the sign onto the frame and put the TEK screws back in place from top and bottom. If the frame is mounted level, the sign will be level. It may help to use an extension driver for putting the screws back in.
This method of installation has the additional advantage that it circumvents any problem caused by uneven bricks.
Another point. For the vertical pieces of the frame, use smaller dimension angle, say 1-1/4" or 1", so they don't prevent the back of the sign from resting flush against the bigger top and bottom angle pieces of the H-frame.
It is possible that there would be no room to easily access the sign from the bottom to drive screws, perhaps because the sign is to be mounted low on the wall or a planter is in the way. In this event, the H-frame can be reconfigured so that the vertical pieces of the H are closer to the side edges of the sign, allowing TEK screws to be driven in from the sides and top instead of the bottom and top. This would mean, of course, pre-gluing vertical lengths of mating angle on the sign back near its side edges.
Using a back frame like I've described shortens the time spent on site. Installers like it, especially in cold weather.
Brad
Sandman
I don't know what kind of crap MDO some people use but I've got signs hanging for 8 years and upon checking them there was zero rot. Either my climate is kinder or their MDO is junk. You have to prep it as well. I epoxy the top and sides.
