I have a client who is asking to put the sign on the shops front. The dimensions are 5'x13'. It is up to us what choice of base board material to go with ( MDO wood, Aluminum, Acrylic). The sign will be mounted straight to the stucco wall using the existing bolts (they are already in place and were used for previous signs) and will be located right below roof line. I'd say 14 feet from the ground to the lower line of will be mounted sign ( I have to use the lifting equipment for that.).
It is up to us the choice of vinyl lettering or digital print. We consider laminating whole thing (obviously) as they want " long lasting" sign.
Several questions:
1. How much that type of work will command in $?
2. How much $ sign alone without mounting will comand? ( Design : Name of the shop and small logo) with choice of different materials for mounting.
3. All supplys we have acces to can provide 4'x8' of before mentioned materials. I guess we have to stack the panels. Aluminum can be welded , but acrylic?. The sign they had before was a painted lettering on a piece of plywood- and I guess they will shy the wooden materials unless we can convince them of longevity of it(???)
What material you would reccomend? We are in sunny Southern California.
4. How to deal with seams for stucked panels. Will they show up in the final work after layering vinyl over it?
This is our first sign of this type and we do it 'cause the shop owner is a friend of ours. So I guess this is a good chance to get foot in the door in this type of business.
From equipment we have Versacam 540v and large format laminator.
I know that these are a lot of questions, but if someone who has expirience in this type of ventures will advise us- we will greatly appreciate.
Several questions:
