hello folks. another new guy here. I have been trying to get my pnc 1000 to start cutting. so far no luck (actually, lots of luck, just bad luck). I bought the cutter off ebay. It runs through its test function just fine.
I have formatted my hard drive, installed xp and corel x3, at this point I am hopping to cut directly from corel. I also downloaded the drivers from Roland DG site. I also have the service and user manual for the cutter (thanks Ian). I bought a parralel cable new from the source and hooked it up with great expectation. Like a "virgin on prom night" things did not go as expected.
I drew a basic circle on corel, converted to bitmap and then traced it (I assume this is how one makes a vector graphic?) I then sent the job to the printer/cutter. An errror message would appear (on the computer) with no info as to what the error was. Upon further inspection I realized the job was being sent to the wrong port on the computer. i changed it to Comm 1 port. Still getting the error message when trying to print. I then looked through my user manual for the PNC and read about input selection. I then adjusted the PNC to recieve info through the parralel port. At this point I thought it would all work. Now I don't even get the error message.
I am not sure if the jobs are going to the cutter, or if I am sending poor info (not a vector) or if the computer even knows that there is a cutter hooked up, also I have no vinyl yet, I removed the blade, will it try to cut with no paper loaded? where should I go from here?
thanks for the help
thanks for the help
