Fuzzy/grainy horizontal bands and color seperation a few feet into the beginning of every print hp latex 360 (update)
IceTrikes
Hello, I posted about this issue a few weeks ago and still haven't solved it, but it has actually gotten worse over time and I have a better picture here to show it.
You can see in this image that above the "P" the print becomes grainy and the colors start separating, then the print becomes consistent and sharp again partway through the "U".
Before anyone suggests that I swap out inks or printheads I've already tried all that, and I don't understand how a faulty printhead could cause this issue anyways. Last time I posted somebody told me it was a faulty printhead, but I just want to make it clear that this fuzzy band only appears one time per print and about 2 feet into the print, not consistently throughout so I'm 99% sure it is not a bad printhead.
Does anyone have any other suggestions or has seen this before? I would be eternally grateful. We are on a budget and hiring a tech is expensive and hasn't really solved issues we've had in the past so trying to avoid that.
Thank you!
ToTo
Professional Support
This looks like an advance problem. You can check using the HP control print embedded in printquality menu. The left and rightmost thin lines should be thin.
Deactivate Omas in substrate setting you are going to use. Or stick something on the sensor surface. Then do an advance calibration and print again. If you still have these various deviation your rotary encoder disc on the left side of the drive roller is dirty or damaged.
The omas sensor should look shiny blue if you look under an angle. If it’s greyed, there’s nothing you can do then replacing.
But even in this case you should be able to print if advance calibration is done on the substrate.
IceTrikes
Hi ToTo I will give this a try. Thank you so much for the advice!
cornholio
Todo is right, except that the control print is not embedded in those old baby latex. Sometimes, the Omas gets "blinded" by dust from the inside. I have successfully cleaned a couple of them. You need to take the omas out and disassemble it, then clean it with compressed air.
Another cause could be the feed roller, that needs a cleaning.
ToTo
Since several firmware versions it is included in baby latex.
IceTrikes
You think this could be the problem even though the issue only happens once per job and doesn't repeat until sending a new job?
BigNate
I know you have looked at printheads - however, I have experienced frustration and what sounds and looks very similar - optimizer print head could be going? maybe something odd like a batch of optimizer that lightly clogs the nozzle and is blasted clear after a few passes? (If the smearing/fuzzy print is in the direction of media feed, then absolutely do a cleaning of all sensors and the fine advance calibration first - these are more likely the culprit)
When I zoom in and look, the fuzziness is definitely worse in the up/down direction on my screen, but even the vertical lines appear to be a bit fuzzy left to right - You may have a compound issue. After you get the advance calibrated, run a calibration on the optimizer and see if it tightens up the edges even more.
ToTo
Yes, this is possible. Omas can still provide good readings for few advances, later the machine might do some false compensations after misreading and deactivate the omas for rest of job.
Just stick something onto Omas and start a printjob. You will immediately see if the advance behaves stable
IceTrikes
Hey again ToTo, I gave this a go and no luck unfortunately. Thanks for the idea though.
IceTrikes
I will give this a go today and get back to you. Thanks for the idea.
