Doyle
I made a mistake on choosing the materials for this project and now I am trying to fix it. We have 30 photos printed on oracal/orajet 3164, 36" x 60" laminated with oraguard 200 matte. I planned to mount these photos to 3/16" gatorfoam, and that is where we are having trouble. I have seen an old thread where this has been a problem for others, but unfortunately we already have all of the panels cut down to size, and most of the graphics are already printed. We started mounting the graphics to the gatorfoam and have found that we are getting really poor adhesion, the vinyl pulls away from the gatorfoam quite easily. We have tested prepping the surface with isopropyl alcohol with little improvement, so now I am researching using spray adhesives. We tested some spray adhesive on a piece, using sprayaway 66c permanent spray adhesive and the vinyl has bonded quite well. The concern I have is that the spray adhesive is solvent-based, and the adhesive on the vinyl is water-based. Does anyone have experience with this combination? Will the bond fail over time, or is there a better solution to this problem? If I had to replace anything at this point, I suppose I would rather reprint the graphics vs. replacing the substrates, as I have over $1000 worth of gatorfoam cut down for this project.
These photos are going to be permanently installed on the walls of a local supermarket, so long-term performance is important, I just did not anticipate having any issues with the gatorfoam. Any advice that can be offered for this would be greatly appreciated!
