Gerber Edge FX printing 1200dpi in flexi possible?
lainke
Hello,
I have buyed a Geber Edge FX last week and my first job is one with small text. I have only flexisign available at the moment so printing with it is no problem. Now i see it flexisign that i can choose between diffrent dpi setting but the machine only takes 300x600 dpi. In the list there i also 300x1200 and 1200 but the machine won't take that. It say "invalid parameters !" On 300 x 600 dpi its no problem. Somebody knows how i can print in higher resolution in flexi?
Vassago
Been here a while..
I think it needs a firmware update to get 1200dpi, but... And don't quite me - if I recall 1200dpi only works with Omega.
Check your firmware - see if updating that sorts Flexi
lainke
I updates the firmware yesterday because i thought that too but thats not helping. I have only flexisign and omega 2.5 available and that doesn't support the higher resolution too.
You never mention what version of flexi, and OUR edges are all older,
But i vaguely remember some odd quirks setting up flexi thermal module printing (v12, i think) for clients.
I will dig through invoices from previous years and hope i listed what was done
lainke
I still use flexi 12 but i have the cloud version so updating to the newest version is no problem.
The problem is not that is doesn't print good but sometimes i need to print small text and that can be beter imo with a higher resolution.
FunkotronXL
I believe the 1200 dpi was intended for CMYK print outputs on the Edge FX, and not intended for spot color usage.
May be incorrect, but, the incremental step ups are 300x300 (Edge LE/Classic mode), 300x600, & 300x1200. If trying to improve fine text you may still get pixel steps/stairs on the Y-axis of the print @ 300dpi res whether it's spot or CMYK
  • Disagree
Adam.Foster
High res mode, 1200x300 makes pixels denser in the material movement axis. Vector based edge quality is improved, halftone banding is reduced, and patterning is reduced with certain GerberTone halftones. Both spot and CMYK printing will see improvements when printed in high res mode. When printing text less than .250 its recommended to use Small text in Omega (true type fonts) for better print quality.
Current edge Firmware is version P build 16. (high res was added in version L) I would also recommend updating the firefile on the Edge FX as you maybe using a foil that wasn't in the older version. Current firefile is 334. It can be downloaded from Gerber at
https://www.gerbertechnology.com/downloads/files/E3Fire_334_SRE.zip
High res mode was added in Omega 4.0. So Omega 2.5 software doesn't have high res mode, Im not sure about Flexi you will need to contact them about 1200 dpi support. If your interested you can upgrade to Omega 7 and Spandex.com can give you a quote.
Vassago
Been here a while..
ITS NOT A FIRMWARE UPDATE ITS USSING ICC PROFILES
First off it's rude to SHOUT.. All capitals is SHOUTING..
2nd.. ICC profiles are for color management, not resolution. You need to change profiles if you change resolution as it affects how colour is reproduced, but the profiles themselves don't change the resolution which is what the OP wanted.
Gerber edges are thermal transfer.. They have a fixed resolution head.. That's the maximum and by missing or pairing "Pixels" they can reduce the resolution. However.. The vertical movement can be changed by telling the motor how far to move between "Pixels", so a firmware update can improve resolution, but if the software doesn't have the option.. You can't use it.. That's how office cannon printers often have 2400x9600 dpi - they change how much the paper advances before printing the next data, but are limited by data rate on the horizontal.
michael Mahoney
WHO EVER DETERMINED ALL CAPS WAS SHOUTING IS AN IDIOT
and Gerber fx has 3 setting 300 300x600 and 1200x600
and I'm not talking cannon printers I'm talking about Gerber edge printers specifically the Gerber fx firmware update and mine has been updated long ago and i was told by an icc profile creator that it is the icc profile now what ?
because pretty weird it works on Gerber Omega @ 1200x600 but not on flexi so there for its not a firmware update
Vassago
Been here a while..
This thread was started in 2022.. youve just reopened it and not even put a question in..
Read my answer.. "but if the software doesn't have the option.. You can't use it.."
Unless the printers firmware has been updated you can't use hires.. If your software doesn't have the option.. You can't use hires..
ICC profiles are files that contain information about how a device (e.g., printer, monitor) translates colors. Not resolution.
Anyone can make a icc profile.. Virtually all professionals do so your printer actually prints the colours you want. You change the ink type.. New profile. You change the substrate.. New profile.. Any new combination = new profile. You don't have to use any profiles, but if you want accuracy - that's what you do.
michael Mahoney
don't matter when the dam thread started who say you got to open a new one when the one i have come to the conclusion you have no clue about icc profiles for printers as an expert from flex sign has already told me i was correct that an icc profile is needed for the Gerber edge in flex sign
as it works like i said at 1200x300 with Gerber software so anyone with half a brain would know something in flexi sign is missing and its not ink ink is a liquid Gerber foils icc profile cant be made as if they are ink color correction for CMYK in Gerber edge printing is a bit different from ink and flexi does have the option to print in 1200x600 its the newest version
it was never a priority for Joseph Gerber to make his technology some bizarre sort of "open source"
to SAI's credit, they developed a "thermal module" because, to their credit, flexi can pretty much print to anything.
1200x300 resolution uses a strange sort of pixel with a 4x3 aspect ratio. developing those algorithms for flexi printing high res to the edge FX may just have been a bridge too far for the flexi team.
we have 3 gerber edge's but rarely print to them except with certain types of work, (which they are REALLY good at!)
michael Mahoney
so were you able to print at 1200x300 you didn't get any paramotor errors
