Gerber Edge Print Problem
yamaha581
We have a Gerber Edge and for some reason when we go to print say it will print through the first color and when it goes to take it back to do the next color the vinyl stops moving and it just makes a noise like it is moving and then once it would be back to where the beginning was the noise stops but the vinyl barely moved. When it happened the first time I figured it was just a mess up but it has happened about 4 or 5 times now so I am guessing that something is needing to be replaced or fixed. Has anyone had this happen to them before?
Fred Weiss
What model Edge?
What software and version #?
What cable setup from computer to Edge?
Does this happen with one particular job or multiple jobs?
yamaha581
What model Edge?
We have just the first gerber Edge, not the edge 2
We are using the USB to parallel
We use flexi to print and have never had any problems
This has been happening on every job we have tried now for some reason.
yamaha581
Does the vinyl once loaded slew back and forth OK?
Yes when we load the vinyl and use the arrows to move it there is no problem with it moving. When it is done printing and takes the vinyl back it almost goes all the way and the vinyl stops moving but the printer keeps making the noise like it is moving but it is more loud than normal and it just keeps making that noise.
