Need Help Gerber Envision 375 cutting inconsistent depths
Kay
Hello, I am trying to trouble shoot an issue with our plotter. We have been having issues with it cutting too deep and through the backing paper as well as not deep enough or not looking like it even scored the surface of the vinyl in some areas all in the same Job. We changed the blade the other day hoping that would fix it and it hasn't. I have tried adjusting the force on the computer as well as the force adjustment on the plotter itself and there was not any noticeable difference. I'm just looking for insight and direction on what the problem might be and the proper steps or diagnosing the issue as well as fixing it.
Thank You!
JulieS
An easy thing to check...is the moveable bar that's on the back side in the DOWN position. If it's UP, the vinyl doesn't lay flat as it goes through. That caused problems for me for a while before I realized...duh :)
gabagoo
I'm having the same issue with my Envision. It seems to shear right through the backing paper on 1 side of every cut decal basically ruining them. Have not figured out why but suspect the cutting strip. I don't use the Edge too much anymore...basically use it for white on clear prints.
FunkotronXL
Sounds like your cutting strip is worn on or uneven across the beam/platen. Try to visually inspect it to ensure it's true from one end to the other doesn't protrude up on one side. Use your finger to feel for indentations in the strip from overcutting or use a flashlight to identify deviations visually.
