Glow In The Dark and Reflective Glow In The Dark self adhesive film
dhenss
Good morning all,
Looking for some suggestions on sourcing some material. I am looking for two different things. First is a self adhesive Glow in the Dark film, the second is a self adhesive Reflective Glow in the Dark film. I have a CO2 laser that I will be using to cut out shapes. Doing some reading I know I need to watch out for the off gasses that some films produce when cut with a laser. I am looking for some suggestions for laser safe material. My current setup has the laser hooked up to a filter box that vents into the room.
Any comments or suggestions are welcome.
Thank you
ikarasu
Look for non PVC glow in the dark, but I doubt you'll find it.... Only recently did they start doing PVC free vinyls.
Your best bet is to get someone with a vinyl plotter to do the cutting for you.
Have you tried to cut reflective on a laser? Reflective uses glass beads... I've never tried, but I'm not sure how good of a cut you'll get out of it with all the tiny glass shards in it.
MNeel
Try AlumiGraphics Glow Grip by FloorSignage, LLC. It is direct print with a glow in the dark coating, plus glass beads and it’s non pvc.
