Thanks much for the info.. We are looking into it. $700.00 for the gun is Nuts IMO! Thanks muchASI 55420 is our goto for basically anything structural. It also dries pretty fast compared to their other offerings, but not too fast to spread. Be warned, the gun for this stuff is stupid expensive, we ordered one without confirming the price, and at $700 I sent it back and found one on ebay for substantially less.
Adhesives | Adhesive Systems MP55420 490ml | Reece Supply
www.reecesupply.com
I've also heard of folks using one of the gorilla glues, I guess polyurethane, I'm not a big fan of the stuff though as it expands as it sets up.
We have used Gorilla glue previously on other substrates. It held great, but the foaming action was not cool. But we will try the method of wetting the surfaces before applying..Thanks so much! appreciate itPolyurethane (Gorilla and similar) are usually used - they are usually foaming adhesives (water vapour), so spread thinly and clamp - as long as the surfaces are clean and you spray a tiny amount of water on the opposite surface, you'll only get slight foaming on the edges - but they need water to cure. You can get 2 part polyurethanes which are better as they don't need water to cure, but are obviously more expensive. Just get some gorilla glue and try on a small sample first.
