GoSign and crop mark selecting
Gary1
Hello everyone. I have a Summa S2 and been having issues with the last few inches of data not being cut due to the cutter
having two usb cables and a powered repeater in between. I don't remember what the length limit was or if it's DATA dependant.
Since I am using GoSign now and just started using it, can I specify
which crop mark to start cutting from and NOT have to start from the beginning of the job? And if for any reason, can I omit certain crop marks
from being detected because of damage to the mark? Someone told me I could. Just verifying. I do not have the Pro Pack, Just the freebie version.
Thank you in advance! I print using SignLab and export to pdf file and import into GoSign.
I found out yesterday it's length dependant. I selected only what I needed to be cut and it did the same thing when it got to the end of the job.
I will be bringing the cutter closer to my pc. I meaured it and it's 30' away.
1upgraphics55
We also have a Summa S2 :) However, we run our print & cut workflow through Onyx Thrive Cut Server. We only use GoSign for plotter vinyl and sign patterns. Personally, I find GoSign so simple that it's super complicated, if that makes sense LOL
According to Google: suggested maximum length for a USB cable connecting a computer to a Summa S2 cutter is 5 meters (16.4 feet). For optimal performance and to avoid signal degradation or communication errors, a high-quality USB 2.0 A/B cable is recommended, often used with a 90-degree connector on the cutter side.
  • Standard Length: A 5-meter (16.4 ft) cable is standard and typically works without issues for USB 2.0 devices.
  • Active Extensions: If you need to exceed 5 meters (16.4 ft), it is recommended to use active extension cables or USB hubs, which can extend the range while maintaining signal strength.
  • Cable Types: While USB 3.0/3.1 generally has shorter recommended lengths (around 3 meters), the Summa S2 cutter operates on USB 2.0 specifications, making 5 meters a standard, stable length for connectivity
Do you have a S2 T160? We've attached the manual just in case you do. Good luck!
  • SUMMA S2 160 T MANUAL.pdf
