Hello everyone. I have a Summa S2 and been having issues with the last few inches of data not being cut due to the cutter
having two usb cables and a powered repeater in between. I don't remember what the length limit was or if it's DATA dependant.
Since I am using GoSign now and just started using it, can I specify
which crop mark to start cutting from and NOT have to start from the beginning of the job? And if for any reason, can I omit certain crop marks
from being detected because of damage to the mark? Someone told me I could. Just verifying. I do not have the Pro Pack, Just the freebie version.
Thank you in advance! I print using SignLab and export to pdf file and import into GoSign.
I found out yesterday it's length dependant. I selected only what I needed to be cut and it did the same thing when it got to the end of the job.
I will be bringing the cutter closer to my pc. I meaured it and it's 30' away.
