Gradients showing up with white box
jcskikus
Owner, Designer & Installer
I agree with Graphic Extremes: either something in a windows update changed things (check you video card update as well), or a preference was checked/unchecked. Question: what is the hardware makeup of the work computer? Old video card perhaps? I've been getting the "your video hardware is not compatible with this version of Photoshop" for over a year.
TEN
A few years ago I was having a weird font issue which was solved by updating the video drivers. Maybe worth a try since it seems like it is that particular machine that it is not displaying correctly on.
unclebun
How do people read the same posts I am reading from yamaha581 and so grossly misunderstand what is going on? I don't know the answer to his problem, but I completely understand what is happening and what he is trying to deal with.
Kemik
I sell stickers and sticker accessories.
If this is just a graphics card issue, then saving it and doing a test print would produce a normal print without a white box.. Correct?
Maybe try that to narrow down what the issue is.
yamaha581
Yes, I can print it and it will not print with the box. I did just notice if I take the design and drag it off of the artboard and into the empty gray space in illustrator the box is gone so the box is only showing up when it is on an art board in illustrator.
yamaha581
if you would like send me the file and I will look at it. See what the file does for me
I can but I can almost guarantee it will work fine for you. It works perfectly fine on my MacBook and my other iMac so it has to be something with this computer. I just noticed if I drag the artwork outside of the artboard and into the grey space the box goes away and the image looks fine.
Kemik
I'm not a Mac user, but it sounds more like a graphics driver issue, try updating or rolling back the driver. Or maybe just change some settings and see if it fixes it?
I use an older Coreldraw and every once in a while I will get the unwanted outline effect. It is a PDF creation anomaly. In Corel if can hand crop the image just inside it's outer edge and that gets rid of the outline.
donkur
I am not sure what caused this but for some reason all of the sudden I am having an issue with anywhere I have gradients in any old files when I open them now they have a white box showing up around them. The only way to fix it is to redesign them which can be a pain for some and especially since it is on any file. I have this illustrator on my iMac and MacBook and it works perfectly fine on my MacBook. Has anyone had this happen before? I checked and there is not an update. I believe it did recently update and not sure if that caused it but I am on the current version on my iMac and MacBook so not sure why this one is giving me issues.
If your file is a PDF, flatten it. Another workaround is open it in Photoshop and re-save it as a PDF.
