rvolkers
are you using CUTMASTER 4?
have you tried to reset registration marks?
they should be a bit thick and no less than .75
use the regular corner registration marks and ALSO run marks up the sides at least 5 inches apart
on the control panel on the graphtec
make sure that your setting used (condition) is all correct - and that the correct blade#s has been selected for the condition being used an
check all offsets at the panel!
