usb troubleshooting
try a new usb cable
plug into a different port on
computer (see if you get "new hardware detected" window
plug a flash drive into usb port on
computer (this shows the computers usb port is working)
if you have a 2nd
computer (perhaps a laptop?) plug usb cable into a usb port. if you dont get a new hardware detected window, we begin to suspect that the usb port on mainboard is defective
if this is the case, we need to setup serial communication (this is not plug &play)
the good thing about serial port it is a lot more rugged than a usb and will probably work forever once it is setup
if you think you have the right cable (and usb to serial adapter if needed) we can match plotter settings to computerr settings and get you cutting again.
if you pm me, we can take a run at it tomorrow, if you like
Good Morning Ladies & Gentlemen,
Im having some kind of problem with a GX-24 the USB is not responding anymore 'not connceted'
I've even try via the Serial port also but no good..
Any help how to fix out this issue??
Thank you,
Alex
