Having issues laminating
mclerebout
There is a knob on the front of the machine to tension the vinyl roll. I flipped the spool, routed in front of the lower top roller and behind the lower bottom roller and it would feed in the rollers that way. He had 2 aluminum angle brackets mounted to the machine. I bought a piece of plexiglass and figured I could put my vinyl there to feed in. I'm not at home now but I think the top feed roll had to come off over the top and around both lower bars and the adhesive side of laminate is facing the bottom. Yes, the top feed roller is up top at the back and the take up roll is at the front
mclerebout
There appears no way to have any tension on the vinyl or to be able to at least have it go around the bottom roller. If you are lucky you might get a foot on two before the vinyl bunches up even if you set the nip pressure as low as possible.
If you web the over-lam around the bottom roller on the back side it looks like it could feed under the heater with the release liner feeding to the take up roll after it passes under the heater. The laminate coming off the bottom I don't see any feed from the bottom in any of your photos. Or are you talking over or under coming off top feed roll? Looking at your photos it looks like the top feed roll is to the back at the top and the take roll is towards to front. Is that correct?
There is a knob on front of the laminator that is used to adjust the tension on the vinyl roller. I can route the vinyl around the the 2 rollers and enter the rollers on the backside of the machine and it would go under the heater beforehand.(online it said it should be heated before being applied)(even though the laminate i'm using isn't heat activated). I just have to have the roller direction set to "reverse". I can't figure out a way to feed it through the front of the machine. I've tried with spool both ways feeding off top and off bottom and there's no way to feed it through either or both of the rollers and have it not rub against the square heater cover to feed it through the front. Yes, the feed roll is on top at the back and the takeup is on top at the front.
dypinc
As best I can make out from your photos here is how I would web the over-lam. This is with the machine running forward.
dypinc
I will see if i can route it that way and have it not rub against the heater shield. I appreciate it!
Probably won't hurt anything to have the release liner rub against the heater shield. If you are using PSA lam you shouldn't need to apply any heat.
ecilop
You might try this. JMO
Looking at the machine from the front:
  1. ORAGUARD 210 supply roll — the upper/rear roll.
  2. The laminate comes down from the supply roll.
  3. It passes behind the silver “DANGER HOT” heater/shield box.
  4. It comes down and around the orange rubber laminating roller.
  5. Just before/at the orange roller, separate the release liner from the clear laminate.
  6. The clear laminate continues down into the nip against the printed face of your vinyl.
  7. The release liner travels upward and winds onto the take-up reel.
  8. Your printed vinyl enters from the front, with its printed side facing upward toward the adhesive side of the laminate.
  9. Once you have the laminate threaded under the orange roller be sure it is pulled tight from the back side and straight before you lower the roller. That will probably be a 2 man job.
  10. Because of the distance to the take-up reel from the orange roller, you will probably need to run some sacrifice vinyl through the laminator to get the backing paper to the take-up reel. The laminate and backing paper should separate at the bottom of the heater box.
mclerebout
Thanks ! I will try that and let you know. Can I also use a solid piece of something same width as laminate roll to stick laminate to and pull past roller so its taught?
mclerebout
I ran it this way and it actually laminated pretty good! My only issue is I don't understand why there is little pieces of things that are between the laminate and vinyl in random places. I purchased an antistatic tarp to keep the machine covered and clean. Does that static electricity suck stuff in or what? I guess once i figure that out i'll be good :)
ecilop
Yes, static electricity will suck everything it can into your laminate. When we laminate, we use a microfiber cloth to wipe the print as it goes into the rollers. Our laminators have a safety bar to keep your fingers (and the cloth) from getting laminated. Can't tell by the pictures if yours does so be careful if you try it.
dannyd1962
Remote Freelancer
Make sure your location is temperature controlled and your humidity levels are good, not dry, as that will be a likely cause of containaments getting into your laminate while its working.
mclerebout
It is. I installed a minisplit and keep it at 75F. Minisplits don't shut off but go into a low power mode when it reaches the set temp. I am going to try turning it off though when I do laminate and see if that helps with it sucking in any dust/debris. I'm also going to look into other methods to deal with static electricity and see if that takes care of it
  • Agree
Reactions: 1 user
Humble PM
Mostly tolerates architects
Vacuum and mop the floor in the evening, then again in the morning - the laminator looks like it sits pretty low down. Also use some scrap laminate, or app tape to remove any dust from your clothes. Swiffer dusters to get dust off the machine (or a damp cloth or tack-cloth)...
  • Agree
Reactions: 1 user
JBurton
Signtologist
You probably want to get an air compressor and blow the machine out pretty good, and even give it a few solid whacks with that dead blow to knock any dust loose. Then mop and vacuum.
