Having issues laminating
mclerebout
So.... I am a newbie to the vinyl printing world.
Laminating is totally new aswell. I picked up a 30 inch commercial laminator and had the rollers rebuilt because they were all cut up.
I tried laminating some vinyl and there was creases. I read online it could've been spool tension and I did notice it was pretty tight.
I loosened it up some and tried again.
I had it pulled tight, even slack on both sides, put top roller down. After doing a little bit of the vinyl I noticed it looked like this.
It didnt look bad on the vinyl but was wondering if by looking at the picture anyone has any ideas on why its looking like this.
Thanks in advance.
White Haus
Not a Newbie
Welcome to Signs 101, and the to the joys of laminating.
Without seeing a picture of the whole set up, I'd say your laminate wasn't fed/webbed evenly. There is way more tension on the right than on the left, causing it to buckle.
What kind of laminator is it, specifically? Can you provide a picture of the whole unit? Just curious how the nip/height is adjusted and how the feed/takeup rollers are set up. Seems odd that the film is running over a square bar rather than a dancer/round bar or tensioner.
We use a coroplast sled to web up our laminator, have done it this way for 15+ years. Start your laminate and hang it over the top roller, tack your coroplast sled to the laminate and shove it through, drop the rollers, then shove in your prints.
  • Agree
Reactions: 4 users
Steenland
Old Member
I agree with White Haus, it looks like your machine may not be webbed properly. The laminate should be hitting the orange roller much farther back on the roll, so it has more time to flatten before reaching the nip. I would suggest that the laminate should be passing UNDER that metal bar, with the liner separating at the lower edge. If your photo IS showing the proper webbing, the lam should be coming over that top bar much squarer. It's already too skewed to lay flat. As White Haus said, we need more info/pics.
Don't give up though! Learning how to laminate efficiently can be very frustrating. In my early days I had tons of spoilage. Now I can't remember the last time I spoiled a print in the laminator. One of the most important things to learn is how to check and adjust the nip on your machine to keep it even across the width of the rollers.
  • Agree
Reactions: 1 user
mclerebout
After i posted this I did think it was not normal that the laminate was against the square piece(cover to heater) so I did reroute it but it's probably still not right. There is 2 bars below the media holder(or whatever it's called) but I wasn't sure. The laminator does not have a brand name on it anywhere. It does have a model number. It uses air pressure to raise and lower the top roller.
I have attached some pics. I was also wondering if in the front of the machine where the vinyl is if it not being a flat surface could contribute to it not being webbed correctly.
The video I watched online just showed using a piece of sacrificial vinyl between rollers, pulling the laminate against and under the top roller, lowering the roller, and that was it.
mclerebout
I really appreciate you taking the time to try to help me out! I really was trying to figure out how to learn without wasting vinyl but came to the conclusion that's not possible, lol. One thing I did notice aswell on the machine is when I lower the roller one side drops before the other. I think because the laminator is pressure sensitive I can only use the pressure knob to set what psi i want. Does that sound right? I know when I had the rollers rebuilt I had to take the machine apart and then put it back together and there's no adjustments for roller placement other than just lining them both up left to right but no up/down adjustments.
dannyd1962
Remote Freelancer
Make sure your tension is the same on both sides of the rollers, make sure the laminate is centered on the machine, along with the vinyl, and make sure nothing is skewed as the laminate is hung from above and needs to be centered.
  • Agree
Reactions: 1 user
Stacey K
I like making signs
Make sure you aren't using too much pressure also. I just have a manual 52" Vevor but the biggest learning curve was realizing I didn't have to have that much pressure for the laminate to stick to the vinyl. But this looks more like webbing.
Often, I will start with my rollers loose, add a few inches of vinyl and lam then tighten the rollers. I guess that would be manual webbing?
mclerebout
honestly i don't even know how to route the laminate. I looked online and it says it should be heated before it's applied and in order to route it that way the laminate would have to enter the rollers from the back of the machine which can't be right because when i have the "forward/reverse" switch on "forward" the direction of the rollers would pull the laminate in from the front towards the back, not reverse to front.
Steenland
Old Member
Wow, sorry, but I'm having trouble figuring out this machine from your photos. Is there any way we can get a photo of the ENTIRE machine from front and back? I can't tell which is the supply and which is the takeup, and what the heck is that spindle sticking up in the air?? Maybe that's the idler bar and it's mounted upside down??
The entire roll should drop evenly, not one side first. Could be a lubrication issue, but more likely a pressure setting. This should be adjustable on at least one side.
I assume the machine came with zero documentation. You mentioned watching a video, was it about this specific machine, or just laminating in general?
mclerebout
if it's a commercial laminator, go to the website and print yourself a user manual
There is no manufacturer or anything on the machine. There is a model number. I have tried searching and nothing comes up for the model number so I have no clue.
Steenland
Old Member
I'm still just guessing without more info/better pics, but the spindle that's sticking up is there for some reason. I think maybe that's your supply spindle. I honestly can't even tell how you mounted your roll of lam on the spindle that it's currently on. From the photos, I would have guessed that's part of the frame, not a functioning spindle.
I believe the thin metal spindle behind the main roller is your idler bar. Here's a possible webbing route: Your lam should feed down from that high spindle and under the idler, then forward and over the main roller (while the liner separates and goes up to the takeup spool), then through the nip. The thing is, I don't see how the lam interacts with that heat shield thingy, whether over or under. I've never seen a laminator that doesn't heat the lam via a heated roller. (I only use PSA anyway, I hate heat-activated.)
mclerebout
The thing sticking up has a razor blade and a weight to trim a roll of laminate. What do you mean "main roller"? The laminate im using isnt heat activated. The heat is optional on the laminator. The spool that the laminate goes on is on top in the back. That was marked. The spool up top in the front is the takeup and next to it is marked "rewind" with an arrow facing the laminate spool. Ive tried having the laminate spool where the laminate co.es off the top and bottom but couldnt see any way to route it through either or both bars below it and into the front of the machine without it rubbing against the heater cover. I did find a way that might work tonight and that was have the laminate go straight down, in front of the 1st bar under and behind and around the lowest bar and it could meet up with the vinyl there and go through the rollers. The only reason I dont think that is correct is when the machine is in "forward" the rollers would need the laminate fed from the front. If it was in "reverse" it might work but obviously makes it seem wrong.
netsol
what is model #?
there are databases we used to have to use to identify manufacturers
these companies will often make product under 20 different names
dypinc
Looks like your first roller that your over-lam should go around is the lowest roller at the back of the machine, and then feed around the laminating roller with the release liner take-up coming off at the top of the laminating roller. Machine looks like it might be useful for mounting to substrates but for lam to vinyl it looks like a disaster creator.
mclerebout
I was told that the person who owned the laminator did run a print screening business. What do you mean it looks like a disaster for laminating vinyl? Is the "over-lam" you're speaking about is the roller for the backing paper? Sorry for being dense, I am trying to follow how you are saying it should be but don't understand. No matter if the laminate is coming off the top or bottom there is no way to feed it around either of the 2 bars below that and route it around the front without the laminate being against the square heater cover
dypinc
There appears no way to have any tension on the vinyl or to be able to at least have it go around the bottom roller. If you are lucky you might get a foot on two before the vinyl bunches up even if you set the nip pressure as low as possible.
If you web the over-lam around the bottom roller on the back side it looks like it could feed under the heater with the release liner feeding to the take up roll after it passes under the heater. The laminate coming off the bottom I don't see any feed from the bottom in any of your photos. Or are you talking over or under coming off top feed roll? Looking at your photos it looks like the top feed roll is to the back at the top and the take roll is towards to front. Is that correct?
