OK, after months of research and fiddling about I've finally found a UK supplier of HDU and the high solid content primer I believe is needed to seal the pores. I have the CNC and I have the 3D software sitting here ready to rock- I had been meaning to do a load of test pieces and the like but just haven't got round to it.
I now have a proper paying job for a pretty small HDU sign so I've got no choice but to get on with mastering HDU- the customer was looking at some US sites and loved the look of HDU- something I'm sure lots of other people will be interested in over here.
What I'm trying to find out is how to properly paint the HDU once I've chopped it into the blank. I had in mind to lightly sand the bare HDU and apply two coats of high build primer with a fine sand in between. For ease of final decoration I was thinking of adding cut out HDU letters instead of hogging them out of the main panel- I'm struggling to find a recommended adhesive I can easily source in the UK- does anyone know what type of glue the stuff the HDU companies in the US sell is?
I can only get HDU in 1500 x750mm slabs in 40mm max thickness. Are there any nifty techniques for joining slabs and hiding the mark?
The sign is 4ft wide by around 6ft and it's fitting flat to a special wall the customer is building (talk about adding pressure- can't afford to muck this job up can I
. My plan was to back the HDU with a 3mm Dibond panel cut to fit the outline of the panel- maybe making a pan out of it so I can mount the whole thing without big coach bolts and washers through the face of the HDU.
In terms of paint for the final finish I was thinking of specialised sign paint rather than DIY store stuff. Would one shot be a good choice? Alternatively I can get the full Spraylat range of sign paints but I'm not sure of the precise range to specify. Generally I'm not a huge fan of water based paint so a solvent would be my choice- if you think this is wrong please do say.
I am also thinking of adding some gold leafing to elements of this sign- would the standard sizing work? would I need to laquer/ varnish the leaf after applying?
Sorry for all the questions. If any of you HDU guys can give some tips I'd be very grateful.
Cheers
Andy
Cheers
Andy
