Help! Gerber edge le
jowen
Today my gerber edge le start great but when I try to print other job it freeze. I turn it off then when I turn it on it beeps many times without stopping. I turn it off again and turn it on again and keeps the beeps and I hear the fans. What is wrong??
Fred Weiss
Sounds like a power supply or a driver board problem. You should be able to contact your Gerber distributor for support and modular parts for switching out to fix the problem.
jowen
I think I fix it. I hit it a little in the front and it turns again. It works great. Can it have something lose inside?
jowen
It is working. But I can't find anything in the manual.
Fred Weiss
You should probably take off the sides and front; blow it out; and then remake all your cable connections ... including the ribbon cable to the LCD.
