Question Help Mimaki Jv3 160sp
zex123
I have this problem, someone who can help me what's the problem?
  • image-0-02-05-415e624f32c6edea9cd9f5fa76ab1c9cccdcaef8611c5b77a8eef8126d2bc9e9-V.jpg
  • image-0-02-05-5b72c0b4a0397a8fa5541c9839309427ca58c3d4fb0d275198f08e605cc117f8-V.jpg
  • image-0-02-05-89c4eab1ffa69e91c6dd69db3247af13ff0de48ac64958dc50cb7df2c4d79ec6-V.jpg
zex123
tnx blackthorn i cleaning the encoder strip and sensor,
now is much better but not completely , if I buy a new strp? or tray something else?
pic after and before cleaning strip
OmegaAdv
he mean feed compensation - my is around 60. you have to get a good colors without banding. Try when you print to click function button and change the value.
With what parametres you have print the 3rd image. Resolution passes?
If you have better result buy new strip.
zex123
3rd image is print mode high quality 720x1440 16 passes
OmegaAdv
make print align
feed comp during printing.
There were a lot of other points which tech will tell you, Im not, but my printer prints on 720x360 and I like prints more than that. Also my test page is not good as your
zex123
make print align
make print align
feed comp during printing. What exactly you think?
they should be more to do to get even better results?
OmegaAdv
Print align (Print Adjust)
For bidirectional printing, the printer must know the distance from the print head surface to the media surface. This allows the outbound and inbound scan
passes to land on one another. This ink travel compensation is set in the MAINTENANCE – PRINT
ADJUST menu.
• This setting is not referenced for unidirectional printing.
1. Select PRINT ADJUST from the MAINTENANCE menu.
2. Select appropriate head height under HEAD HEIGHT.
3. Enter the best aligned
Feed compansation: During printing - > FUNCTION -> ENTER and change the value. You will see that when the pass overlap the first pass or make gap. It is very precise I think that 100 points = 0.1mm
zex123
ADJUST menu.
WHAT now? thank you so much for helping me :)
thin or thick what is?
