CENTERVILLE SIGNS
It's plugged in
THANKS ... expensive to fix ? ? ?We just went through the same and it was the main board and a bad switch.
YepTHANKS ... expensive to fix ? ? ?
The only fix as such is to replace the mainboard, but you need to get the other things tested first to find out why it isn't coming on. I have the replacement parts in stock if you need themTHANKS ... expensive to fix ? ? ?
The main board is $3000 with installation, travel, and sales tax.THANKS ... expensive to fix ? ? ?
THANKSTHANKS ... expensive to fix ? ? ?
i normally will only buy a system board from someone who is a power seller.I bought a motherboard on eBay, but I ended up with a broken one, so I had to send it back.
Normally that error comes from the black head thermistor and it's telling the printer the head temp is too low because the mainboard is not getting the correct value from the head. This can either be a bad head, bad cables, print carriage board or mainboard. At this point you are better off getting a tech out to look at it reallyHello everyone, I have finally replaced the motherboard. The machine turns on, but I’m getting a new error message: "temperature too low." In service mode, the temperature reads between 0 and 32. Could you please help me?
