Hi everyone,
I have trouble cutting vinyl with my Summa d60s,
new Blade,
new strap, I attach a video, so you can understand better my issue.
Basically the issue is that during a vertical cut in one direction when cutting the sheet is being lifted by the Blade, resulting in bad cuts,
that's happening only when I try to cut the first 15 cm of the vinyl, I think after that length the weight of the vinyl helps the "lifting" problem.
here is the Video.
Thanks in advance for any help or suggestion.
new Blade,
here is the Video.
