hamit12280
Hi everyone ,
What is that printers problem can anyone help me i dont want change heads
First problem is blue ink near the printing even the C0 M0 Y0 K100 , its like dust with blue color
And i can clearly see light blue is dripping the cleaning sponge
Last problem the LC test print is looks terrifying
Ink's are aftermarket nazdar setup ,no white,metallic and else
James Gallant
Graphic Designer
Sorry to tell you, but you will most likely need new heads. You can try a 48 hour head soak by capping/closing the lines after the cap top and filling the cap tops with cleaning liquid and then setting the head back in place locked into the cap tops, refill cap tops after 24 hours, then at the 48 hour mark, run a powerful cleaning and then try a nozzle test. If no improvement, you'll need to replace that head.
  • Agree
Reactions: 1 users
Yes, that is correct. It looks like tso bad heads.
Possibility of a bad light cyan cartridge or expired past. As you know, there is one light cyan cartridge that splits to both heads. So being that this happened on both heads, it is most likely bad ink. The complete ink line should be flushed out.
By the way, what type o4 brand of ink is it and what is the date code?
  • Agree
Reactions: 1 user
hamit12280
Thanks for answer, i will try that and tell you what happened...
hamit12280
Thanks for answer, i use NAZDAR 203 series .My Light magenta did same think and i change inks to nazdar, now the light cyan dids im very tired of this machine
