Help with font not closing in corners and connecting strokes.?
JR's
For some reason this font
Montserrat does not close.
It has open areas,
where the strokes connect and in corners.
I seen this before but I don't know how to fix it.
Any help greatly appreciated
The Vector Doctor
Chief Bezier Manipulator
try using a weld or combine tool. Not sure what it would be called in your software. Many newer fonts are being built this way. They look ok when printed but need combined before cutting
Reactions: 1 users
jwlllpl
Group and weld TWICE. Not sure why two times is necessary but that is what works for me. I use CorelDRAW and Illustrator but probable works the same way in Sign Lab.
JR's
Thank you guys! You put me on the right path. LOL pun intended.
What I ended up doing is breaking path, and then weld. It worked with one weld.
But thank you guys for the input it put me searching in the right direction.
Reactions: 2 users
CD GRAPHICS
This is a known issue, and it explains the HG image.
Why it happens: many modern fonts, especially variable fonts (the ones that include every weight in a single file, like Chillax or the fonts from Adobe Fonts), don't draw each letter as a single shape. Instead, they build it from overlapping pieces. The H, for example, is two stems and a crossbar stacked on top of each other. You don't notice it on screen, because the program fills everything in black.
What happens in CorelDRAW or Sign Lab: when you convert to curves and use "Combine" (Ctrl+L), CorelDRAW merges all the pieces into a single object with a fill rule that creates a hole wherever two pieces overlap. That's why you see the white lines on the H crossbar and the white triangle on the G: they are the areas where the pieces overlapped.
  • Informative
Reactions: 1 users
Daniel OTW
another work around is to surround it with a box and use a smart/interactive flood fill to fill the negative space and remove the original curves. Flood the newly created negative space, then remove the box and you are left with a clean solid curve
Bobby H
Arial Sucks.
Overlaps in letter strokes are common with variable fonts. Some fonts have more overlaps than others. And then some of them appear not to have any overlaps, but do have them in some sharp corner areas.
Another hazard: some regular "static" fonts have the overlaps too. Google Fonts has a number of type families that fall into that category -like Montserrat and Roboto to name a couple of the most popular ones. The variable fonts and regular TrueType fonts have the overlapping strokes.
Moral of the story: ALWAYS check the outline view of any artwork that is destined to be cut in a vinyl plotter or cut thru material on a routing table.
In Adobe Illustrator the Unite Pathfinder is good at welding over the overlaps. It's also possible to do non-destructive things, like check the Attributes panel and check the object's winding setting, be it non-zero winding or the even-odd winding. We want non-zero winding. That can visually fill the overlaps without actually welding the object. The Appearance panel can be used to adjust the stacking order of the object's stroke (if one is applied).
In CorelDRAW I have a custom shortcut "w" key set for welding objects. That comes in handy for welding over things like overlaps in variable font objects that have been converted to outlines.
I dont think those are really fonts but shapes, And I have seen that effect before in Corel where they cancel each other out when overlapping.
myront
Dammit, make it faster!!
Or create boundary, use smart fill to fill the insides of characters, delete original, select all and combine.
p.s. tried all day to come up with a macro using Bahnschrift (another "'effed up" font) but no success.
myront
Ok, I did it. I now have a CorelDRAW macro that will fix the Bahnschrift font, or any other fonts that are made this way, for cutting. In the case of the OP, the font was converted to curves first. I'm almost certain the macro would work on the Montserrat font.
p.s. if anyone has or knows of a font that is like Bahnschrift font ,let me know. I'd like to do some more testing.
