Help with Graphics Effect
Jim C
Hey everyone, I was hoping to get a bit of help on something.
I have a logo from Mt.Dew and was looking at it in Adobe Illustrator and Corel Draw.
I am trying to figure out how this effect is obtained. In Illustrator it just shows as an an image in the layers pallett, but in corel it shows as a Monochrome bitmap. Here are 2 samples of what I am talking about. One is a tiff of the image or bitmap and one is an .eps of it to show it does have transparency as well. Without a clipping mask. Any help is greatly appreciated, not sure if this is the right place to ask this just that I have tried elsewhere and no replys. Thanks
http://w12.easy-share.com/857816.html
iSign
since I'm on my home machine I was more willing then usual to download a file... but once I unzipped the .eps file, I couldn't open it in illustrator CS1 because it must be a CS2 file.
Since Adobe prevents me from activating my copy of CS2 on more then 2 machines... I do without it at home, so I couldn't look at it.
But are you saying that it is only a placed image (bitmap) anyway?
Are you trying to recreate this same logo, or needing to obtain a similar effect...
...or just curious what technique may have been used in the first place?
I had a similar effect that stumped me recently, & Fred found the method in Illustrator CS2. I'll go find that post & edit in the link here in a minute.
..ok, Fred posted this screenshot in his REPLY indicating that the effect in question (on my post) was "feathering" the fill in a vector contour in CS2. There was other discussion about other ways to achieve similar effects in Corel. That entire discussion is HERE.
Jim C
Well I am not sure if it was a placed image or if it started out as objects then was rasterized and then the effect applied. But yes I am just trying to find out how this effect is obtained for future use for myself. Sorry about the file not working for you here is an updated saved as AI 8 compaitablity. Try this one see if this works. It may help you to see the effects better. But as I look at this part of the logo it does look very simular to be as if a eraser was used that would erase in pixels. If you zoom way in you can see it is very pixelated (squares).....Thanks for all the help
http://w12.easy-share.com/857933.html
iSign
everytime I click your download links, I get different pics of Hawaiian girls on the beach:Cool 2:
(I know... the rest of you probably get pics of midwestern moms scraping ice off their windshields... oh well :tongue: )
...anyway, I looked at the .eps & it is just a placed rastor image. I'm not sure what you meant about "transparency" earlier... but i agree that the edge gradiations are unique & don't look bad for certain applications.
I'm not sure how it was done, but can guess that a setting for "noise' may have been part of the answer.
For others benefit in solving this mystery, here is a closeup of the edge treatment in the rastor image I downloaded:
Jim C
Well what I mean by transparency is if you place any image into AI and then export as a .eps and do not apply a clipping mask you will not have a transparent image meaning that it will have a white background as your rastered image does you posted. If you open the .eps I provided and then look all you want it has no clipping mask applied, and export it as a .eps it has no background as usually it would without a clipping mask. I don't know maby I am not good at explaining what it is I am actually asking for here. Maby this effect is simply done with a plugin I don't know about.
iSign
ok.. I get it now. I checked the transparency setting in illustrator, thinking you had theorized it to posibly have been created in illustrator based on some illustrator-based atributes being applied in illustrator. I guess it is still looking like a placed image, but a transparent .gif perhaps.
Mason
The effect heas not been created in Illustrator, My guess, since there is no layered file, is that the red portion of the shape was created originally in Illustrator and then imported into Photoshop and the edge effect was applied there by creating a white shape and adding the noise filter. If you then eport it or import it into another program as an eps the white background by default will disappear. The actual image in the eps is a tif named; "Code Red 12pk Fr Dither-3.tif" you can locate it in Illustrator by opening up your Links pallette. It should be quite easy to reproduce the effect using photoshop and and saving as tiff.
Rick
The simplest way I can explain it is...
Design logo shape in Illy/Corel
In Photoshop
place shape as a guide.
erase area that you want dithered
gassian blur
texture<grain
punch out area of the logo
You can then save at a transparent file or stick it in Illusrator and make it into a Bitmap (make sure the graphic is black) with transparent backround and change the colors as needed
Firemap1
Looks like it was airbrushed after it was brought into Photoshop. Either that or it was placed as a layer on a white bacgroud layer and the eraser tool was used with a heavey feathered edge.
Jim C
Ahhh that is more I think what I was trying to ask and or find out, was this effect done in AI or whatever sorry I didn't ask at first. Thanks so much Mason And iSign for all the help...... I see now that if I make the shape in photoshop and import or place into AI as a tiff it wont have a background if I choose to save transparency.(DOH!) Anyway i liked the effect and could see a future use for it but just wasn't tallented enough to figure it out on my own. Thanks again for all the help.:signs101: :thumb:
Jim C
OK I really appreciate all the great help here. I seem to be a bit confused Is there anyway we could get more detailed in how to accomplish this.... Maby a small tutorial. I just can't seem to get it to work.
Jim C
Thanks for the tools replicator. Just wondering has anyone tried to get this exact look(effect)
attachment.php
I havn't been able to get it, If someone does know exactly how Please let me know this is bugging me to death:smile:
Firemap1
Jim C.
Just to learn the process.
In photoshop create a document 5 x 8 inches with a white background x RGB x 150 dpi.
Go to "Layer" and click New Layer
In this layer, using the rectangular marquee tool, create a selected box covering half the new layer. Leave selected. Foreground color should be changed to red.
With the "paint bucket, fill with red. Then deselect.
Click on the airbrush tool and choose the largest brush with a feathered edge.
300 should be good. Mode should be "Dissolve", Pressure 50%. Foreground color should be white.
With the airbrush tool and the red layer selected, cautiously airbrush the lefthand side of the red layer till you get the pattern you want.
Now Make another layer. In this layer marquee in the black box. Foreground color should now be changed to black. Fill the selected box with black.
In the layers panel, and with the black box layer selected, choose send to back.
Now select the red layer. Now click on the "Magic Wand tool. Set the tolerance for 12. Click in the middle of the white area. After it is selected hit the delete key. You should now have what you want.
Irish
Rick
In Photoshop CS2 you can also try...
Go to eraser
Pick a brush preferably with a fade. Then in "Brush Presets" choose "Noise" "Airbrush" and "Smoothing"
and have at it.....
You can also control the flow and opacity depending on your needs.
Oooops, you don't need scattering
Jim C
Ok that works great in Photoshop but none of this is working in AI at least not for me I guess I just don't know enough to figure this out on my own. Back to the original file I posted as you can see it has transparency without a clipping mask. If I make a shape the same as it in Photoshop then place or open into AI it has some background that is not acceptable. So back to the original post if someone can figure out exactly how this is done Please let me know thanks for all the help so far guys. I have learned some other useful tips for the future, Just not what I am looking for in this effect. PS If you also look at the two pics that iSign posted close ups you can see also that it doesn't appear to have a feather effect which is what i am getting doing it the other way in photoshop.Grrrrrrrrrrr
Rick
Do you have the logo on it's own layer, did you remove the backround layer? and any backround color? can you see the checkerboard backround?
Then when you save it as a .tif did you hit preserve transparency?
Jim C
Yes it was it's own layer and yes I checked preserve transparency. I just don't get it when i stare at that effect it looks like it should be something that is so simple......wait thats probly the problem it is something that is so simple everyone is overlooking it ROFLMAO
