Help with Kawasaki Green
cyclerc
Can someone help me with Kawasaki Green, Mimaki jv150 8 color setup.
Using rasterlink color correction ,
I can pay if someone have the right setup for very close match.
Technician
Drive it hard
I think it will be hard to reach Kawasaki green with that colour setup you’re machine has. Must have green to match. Maybe with some profiling you can come closer.
IsItFasst
Their green has changed over the years and varies sometimes for different models so just trying to find "Kawasaki Green" won't really work. If you have the part in hand then your best bet is to do as the image shows and print various color swatches to try and find one that matches.
Vassago
Been here a while..
What I've done in the past is quite simple.. Take a close up picture of the object and a swatch (rgb values - same picture) - then compare greens (rgb values) in a photo editing program - once you've got the offsets from the swatch, check the object. Then convert rgb into cmyk. Pretty simple to get a good set of cmyk values - it should be a pretty good match, if not it'll be a good start.
