Help with Roland EJ-640 High Temperature
This is most likely a bad left head. The thermistor is on the left head with senses the temperature at the heads. You can reverse the short ribbon cables to verify. It will most likely be one of the heads if your room temperature is certainly lower than 42 Celsius.
  • Agree
Reactions: 1 user
Jim Hancock
Old School Technician
If you swap ribbons, you must swap in pairs. Never swap the 2 ribbons on a single head, as the two connectors connect to different circuits internally in the head.
  • Agree
Reactions: 1 user
cornholio
The EJ uses two "DX7 gold head" and is connected by 2x4 flat cables.
  • Agree
Reactions: 1 user
Jim Hancock
Thanks for the correction. I was thinking DX4 heads. I should have looked it up before posting. Ribbon swapping is not an option on this printer and on DX7 heads, period.
