Help with Roland EJ-640 High Temperature
This is most likely a bad left head. The thermistor is on the left head with senses the temperature at the heads. You can reverse the short ribbon cables to verify. It will most likely be one of the heads if your room temperature is certainly lower than 42 Celsius.
Jim Hancock
Old School Technician
If you swap ribbons, you must swap in pairs. Never swap the 2 ribbons on a single head, as the two connectors connect to different circuits internally in the head.
